The cookie settings on this webpage are set to ‘allow all cookies’ to give you the very best experience. If you continue without changing these settings you consent to this - but if you want to you can change your settings at any time at the bottom of this page.
Cookies are very small text files that are stored on your computer when you visit some websites. We use cookies to make our website easier for you to use. You can remove any cookies already stored on your computer, but these may prevent you from using parts or our website.
The UK's most powerful wi-fi signal vs major broadband providers
The new BT Smart Hub is so smart that it can give you a superfast, reliable wi-fi connection in more places around your home.
If you're new to BT and you get BT Infinity broadband, we'll give you a BT Smart Hub.
Get BT Infinity broadband
Already got standard BT Broadband? Great! We've made it easy for you to upgrade to the BT Smart Hub.
Upgrade to BT Infinity Buy a BT Smart Hub
How much better is the BT Smart Hub ?
Our Hub gives you better wi-fi coverage
The new BT Smart Hub is packed with new and impressive tech. It can give you faster wi-fi connections in more rooms than the latest hubs from other major UK broadband providers.
In this test, all the hubs performed differently in each room.
Compare BT Smart Hub against competitors
Wi-fi where you want
People love their home wi-fi, and the new BT Smart Hub is designed to give you fast wi-fi connections in as many rooms as possible.
Powerful wi-fi
Wi-fi you’ll love
Get your household watching the BT Sport App and streaming HD videos at the same time.
All the speed you need
We’ve boosted the standard speed of BT Infinity to 52Mb. The BT Smart Hub uses that speed to give you a superfast wi-fi connection.
Superfast wi-fi
Speed really counts
A fast hub means smooth video streaming and super quick browsing to find your favourite content.
Get future-proofed
The BT Smart Hub supports the next generation of wi-fi standards. That means it’s future-proof and could support more and more home appliances as they become wi-fi enabled.
Next gen wi-fi
Get more devices online
The BT Smart Hub can get lots of devices online at the same time. That means more fun for everyone in your household.
Get a hub that helps you out
This is clever. The BT Smart Hub constantly monitors your internet connection. If it spots a problem, it will quietly reboot and make a fresh connection.
BT Smart scan
The helpful home hub
The BT Smart Hub can automatically restart itself, and your internet connection, so you can relax.
Better by design
It took months of painstaking design to create the BT Smart Hub. Eventually, the design team crafted a hub that combines good looks with powerful technology and care for the environment.
Easy to live with The front panel has a subtle colour glow that’s easy to understand. What does each colour mean?
Green. The Hub is starting up. Blue. The Hub is working fine.
Dimensions W 241.9 x H156.6 x D32 [mm]
Slim and sleek
The slender BT Smart Hub fits easily almost anywhere around the home, and its sleek design means it looks good too.
Rugged construction Thanks to its tough outer case and well-designed components, this is one tough, durable hub.
Fits through most letterboxes No more waiting at home for a special delivery.
The latest tech
The BT Smart Hub is a real leap forward in home wi-fi. It’s packed with more hardware and the smartest software to turn your home into wi-fi heaven.
Handy password card No more scrabbling to find your password. Just keep the BT Smart Hub's pull-out card somewhere handy.
Compact design All the cable sockets, and the power switch, sit closely together but are easy to find and use.
See our full test report
Front Front
Side Side
Back Back
Better by design
Slim and sleek
The latest tech
See how Smart Hub stacks up
With the BT Smart Hub you get better tech and better performance. Choose how you would like to compare.
{{hub.name}}
No of antennas No of antennas
Why is it better to have seven antennas?
The antennas deliver your wi-fi signal.
With seven antennas on the job, and clever circuitry to power and coordinate their activity, the BT Smart Hub can give you better connections in more places around the home.
Wi-fi bands Wi-fi bands
Why is dual band better?
Dual-band hubs have a big advantage over their single-band rivals.
With two networks on two different frequencies, you can keep more devices connected, with better speed and reach.
Wi-fi standard Wi-fi standard
Why is next-generation better?
Every few years, technologists release a new set of wi-fi standards to help manufacturers increase speed and improve reliability.
It’s always best to have a hub that conforms to the very latest standards.
2.4 GHz wi-fi band 2.4 GHz wi-fi band
What’s so great about 2.4GHz wi-fi?
The BT Smart Hub automatically selects the best wi-fi for each connected device.
The 2.4GHz band is better at penetrating walls, and that’s what your hub will use if the device is far away.
5 GHz wi-fi band 5 GHz wi-fi band
What’s so great about 5GHz wi-fi?
The 5GHz band gives a fast connection over short distances, and that’s what your hub will use if the device is close by.
Connections Connections
Why is it better to have more connectors?
As well as using wi-fi you can use cables to connect devices to your hub. The more connectors your hub has, the more options you have in setting up your home network.
For example, you might want to use cables for devices that need a permanent connection (like set-top boxes and games consoles), and leave the wi-fi free for tablets, laptops and phones.
Advanced filters Advanced filters
What’s so great about advanced filters
Thanks to its clever filters, the BT Smart Hub does a great job of reducing interference. By reducing possible interference, the BT Smart Hub helps to give you a fast connection with as few “drop-outs” as possible.
USB Ports USB Ports
Why is it better to have a USB port?
You might already be using USB ports on your computer to connect like printers or USB storage drives.
With the BT Smart Hub, anyone who’s using your wi-fi network will be able to share a printer or USB drive that’s plugged into your BT Smart Hub’s USB port.
On/off lights control On/off lights control
Why is it better to have lights you can control?
The BT Smart Hub’s front panel illuminates gently to let you know how it’s performing. But sometimes you don’t need to know, so you can simply turn off the lights and let the hub get on with its work.
Removable password card Removable password card
What’s so great about a removable password card?
No more stumbling around to find your hub’s password. The BT Smart Hub has a card with the password printed on. You can take this card and keep it handy so your guests can connect to your hub quickly and easily.
BT Smart Scan BT Smart Scan
What’s so great about BT Smart Scan?
Pieces of advanced tech, like computers and home hubs, can slow down after a while. So the BT Smart Hub helps you out by scanning for problems like these.
If it finds something wrong, it will wait for a quiet moment and reboot itself.
Supersize your wi-fi
If your home has lots of rooms on lots of floors, you can get better wi-fi in more places by adding a BT Mini Hub.
Simply place your BT Mini Hub in an area where your wi-fi signals are weak. The BT Mini Hub will then deliver fast, reliable internet connections in those hard-to-reach places.
Get a BT Mini Hub
New to BT?
If you're new to BT, you can get a BT Infinity package and the BT Smart Hub comes included.
Get a BT Infinity package
*Recommended retail price £129.99
Already got BT Broadband?
Upgrade to BT Infinity and get a BT Smart Hub included.
Or you can buy a BT Smart Hub on its own. It's just £65 (plus £9.99 delivery charge), which saves £64.99 on the recommended retail price.
"BT's new Hub is faster smarter and ready for the future"
"It's fast, very fast"
"We’ve played around with the new BT Hub and we’re impressed" BT Smart Hub, Stuff, June 2016
"A superfast ISP router"
"BT is about to give your home broadband a MAJOR speed boost"
"The fastest, best router you can get from an ISP"
Frequently asked questions
  • {{tab.tab_title}}
{{question.question_title}}
See all questions
